dimitri77565
Member Since 03 Feb 2012
Offline Last Active Yesterday, 11:56 AM
In Topic: KA DW KUDR02FSSS4 leaking frustratingly
11 September 2014 - 07:32 AM
Make sure no gunk build up in baffle (old D&M  LOL)  could be customer loads wrong causing this.
In Topic: LG FL Washer - WM2077CW - LE Error
11 September 2014 - 07:29 AM
Yes  Dean is right.  The harness same part number has different letter designations  such as (A)  (B)  ©  etc
In Topic: Frigidaire Laundry Center FFLE2022MW0 manual request
28 August 2014 - 06:51 PM
FFLE2022MW0  correct mod number
seems dislexia srickes again
ok i will post this on the appliance forum also
this beast has no Timers instead it is using 2 control boards
customer complaint is that it does not always spin
I put it on normal wash…… it filled then started agitating….. I powered down & restarted on "Rinse& spin"  it drained & stayed on drain for over 10 min until i powered down.
no manual so i can not run diagnostics, i figure it is the control board.  any ideas would be appreciated.
In Topic: Whirlpool Ice makerproblem
28 February 2014 - 07:51 AM
Update:
  Well ice maker cheap, 3 screws underneath to install, short rake fingers, plug is different.
Once pushed back & plugged main harness it started filling.
wish i could publish pictures but failed hi tech school.  LOL
26 February 2014 - 01:21 PM
its for the french door ones, looked up part is cheap $34.  locally stocked heavily, water valve no sales .
Its the one with the short fingers
