Lyall Wood
Member Since 03 Feb 2012
Offline Last Active Oct 14 2012 03:34 PM
In Topic: Beaumark (BEF332CES0) Dryer Drum Spins but Won't Heat
05 February 2012 - 09:44 PM
Well, I am glad to say the issue is resolved. I did more thinking and thought "No they wouldn't do that...." But guess what ...they did. When it was just a modular home the laundry was upstairs. When it got moved downstairs, instead of running a fresh line from the breaker box to dryer... they added a new line patched into the old outlet. Not wired together but paired up in the outlet itself. So two outlets were on this breaker. I checked the line and found the red going to the basement and sure enough it had loosened and there went my other half of voltage. Everything is wired up properly as I can and retested. Dryer is working just like it use to. Thanks so much for the assistance.
Lyall
05 February 2012 - 03:48 PM
My thoughts exactly RegUS_PatOff and Bullstok. Not what you want to hear when troubleshooting but I knew before replacing components in the Dryer I wanted make sure it was receiving the proper voltage. I will let you know what happens. This is a Modular home that got placed on a full basement (an after thought) by the previous owners.
05 February 2012 - 01:42 AM
R & W 117 B&W 117
04 February 2012 - 03:49 PM
I disconnected the red cable from the outlet tested btn the B & W 118V btn the R&W 0 and btn the B&R is 0.
04 February 2012 - 11:55 AM
Checked the wires going to the outlet. B&W 118 R&W 0 B&R 0.... the drama continues...
