Lyall Wood
Member Since 03 Feb 2012
Offline Last Active Oct 14 2012 03:34 PM
Beaumark (BEF332CES0) Dryer Drum Spins but Won't Heat
03 February 2012 - 02:16 PM
This dryer has me stomped. I do not want to buy a bunch of parts. This what I have done so far:
1) Checked continuity on the Thermo Limiter, Thermostat, High Limiter, & Heater coil.
2) Checked voltage on the dryer (L1 B&W = 117; L2 R& W = 117; Across B&R =0)
3) Replaced 30 amp Breaker in Breaker Box... Didn't need it but was an immediate test/fix.
Is there a way to test the Heater Relay (has 3 settings Low, Medium, High)?
Any other tests or things I should check?
Thank you.
