Ra1ph
Member Since 03 Feb 2012
Offline Last Active May 15 2013 12:21 PM
Maytag A310 Washer - Motor hums doesn't turn.
03 February 2012 - 03:58 PM
My Maytag washer (M# A310) won't do anything but hum. The shafts for the motor and pump turn freely by hand as does the transmission.
Is the motor fried?
Carrier 58gs075-ga Blower always on, heat works fine
03 February 2012 - 03:54 PM
The blower is always on even though it's set to 'Auto'. This is true even when the thermostat is set to 'Off'. The heat is working fine.
If I remove the door to the blower enclosure, hold the door switch down so the blower runs, and then bang of the circuit board enclosure- the blower will turn off. It stays on again next cycle.
I suspect the blower relay(s) of sticking
Could this be right? Can they be replaced or do I have to do the whole board?
Thanks
Ra1ph
