Derik
Member Since 03 Feb 2012
Offline Last Active Nov 02 2014 09:06 PM
In Topic: Programming #w10319823
19 August 2014 - 10:33 PM
ANSWER Hello Jim. Programming Mode: NOTE: The Program Code is located on the Serial Plate on this unit after the word Code. 1. Press and hold the Door Alarm Keypad. 2. Press and hold Freezer Temperature DOWN /- Keypad within 3 seconds. 3. Release the Door Alarm Keypad and wait 3 seconds. 4. The control will display PE to indicate the programming mode. 5. Entry is confirmed by pressing the Freezer Temperature DOWN /- Keypad once more. 6. The control will display the current Program CODE. This value should be validated with theProgram CODE printed on the unit serial plate. NOTE: If the Program CODE is correct, the Programming Mode is exited by pressing Door Alarm Keypad for 3 seconds. 7. Press the Refrigerator Temperature UP /+ Keypad or Refrigerator Temperature DOWN /- Keypad to change the digit value with each key press. 8. The decimal point indicates the selected digit. Press the Freezer Temperature UP /+ Keypad to select the next digit. 9. Once the desired Program CODE is entered, press and hold the Freezer Temperature DOWN /- Keypad until the Program CODE begins flashing indicating it has been saved. NOTE: If you attempt to enter an invalid Program CODE the control will not save the new code, but will beep. (The unit will NOT run with a Program CODE of 0000).Once the Program CODE has been saved the Programming Mode is exited by pressing any key. If the new code is incorrect this process should be repeated. The Programming mode can be exited at any time by pressing Door Alarm key for 3 seconds or will exit if unattended for four minutes.
Hope this helps someone with warm brews:)
19 August 2014 - 09:03 PM
? No one knows
19 August 2014 - 08:37 PM
Sorry model 106.72002010
In Topic: Duet washer "WFW9150ww02"
07 August 2013 - 01:26 PM
So any other ideas
07 August 2013 - 12:49 PM
No heater on this model either!also hear click when I plug in if2 pin to ccu! So now what???
Won't fill , won't spin, door lock was locked?
