Derik
Member Since 03 Feb 2012
Offline Last Active Nov 02 2014 09:06 PM
#256202 Washer shaking MAV7200AWQ
Posted by Derik on 28 May 2013 - 09:43 PM
It has a very solid floor! The big spring that's there when u take pulley ect apart when changing snubber??? And how do u know if base is bad???
I was curious if stabilizer bar could play a role in shaking???
#255578 Double oven pleb30t8ccb
Posted by Derik on 22 May 2013 - 12:10 PM
Thanks everyone!!! Relay brd with transformer had two seperate cold solder spots on back of control!!! Resoldered both and back in bizness!!! U guys r awsome and quick to reply!!!
#242581 Microwave gh7208xrs-3
Posted by Derik on 15 November 2012 - 10:43 PM
Unfortunately this part was on back order threw R.Clinic! But luckily another local parts distributor had mag. in stock!!! Lady was freaking out about price and thanksgiving around the corner! And the fact that she has a three yr old broke 1000.00 dollar microwave!!!
#230544 Kenmore Model # 417.44092500 No Spin
Posted by Derik on 21 April 2012 - 12:45 AM
changed two of these door locks this week?and probally 30-40 in the last 4yrs, common problem
#230542 Amana front load washer, NFW 7200 TW . what is the code E2?
Posted by Derik on 21 April 2012 - 12:30 AM
depending on how long ago parts were put in might still have part warranty! I had one given to me because somone didnt want to pay for a new drain pump, I bought a new pump and havent had any trouble with mine??? Knock on wood!!!!
#230541 Kenmore Series 80 Washer won't spin in "Ultra Clean" (normal) Mode
Posted by Derik on 21 April 2012 - 12:10 AM
Sounds like timer to me, have seen this issue with lots of washers over the years and ripped apart the timers to find burnt contacts internally! do the lid lift test when supposed to be on final spin as jumptrout suggested and if still not convinced check timer chart in control panel area and test accordingly :thumbsup:
#230118 mgde300vw0 heats sometimes?
Posted by Derik on 15 April 2012 - 10:59 PM
Finally posting back on this, so I found that the gasline tube that pokes out the back of dryer and connects to inside at dryers gasvalve had a glop of what appeared to be cheap pipe dope (gray)??? Removed the b.s. And worked like a champ!!!! Don't understand how it got plugged with it but ran three loads,one with vent disconnected,one with vent connected and one with all towels!!!
#229910 Frigidaire Affinty won't spin clothes dry!
Posted by Derik on 12 April 2012 - 06:31 PM
Sorry didn't specify spin cycle!!! But the answer is????
#229833 Maytag Washer SAV3655AWW - Burning up a New Belt - Will Agitate But NOT Spin
Posted by Derik on 11 April 2012 - 11:59 PM
Good possibility just did one on similar model and also changed belt(worn) and snubber(1/2gone)Posted Image
#229827 Bosch Nexxt 500 WASHER WFMC5301UC/16 won't final spin
Posted by Derik on 11 April 2012 - 10:21 PM
Was anything in hose that connects tub to the drain pump???
#229825 Bosch Nexxt 500 WASHER WFMC5301UC/16 won't final spin
Posted by Derik on 11 April 2012 - 09:11 PM
Did you clean out debris in drain pump? And if so did it change anything???
#229819 Washer jumping around like a fish out of water
Posted by Derik on 11 April 2012 - 07:12 PM
I suggest you try and find a standard directdrive top load whirlpool washer!!! There tough dependable and easy to fix and find parts for but there not making them anymore!!! But are still some left at local box stores (lowes,menards)! Cost less, clean better, just better period!!!!!!!
#229818 Frigidaire Affinty won't spin clothes dry!
Posted by Derik on 11 April 2012 - 07:07 PM
Could have a drain pump issue as well if it's not emptying water in drain part of cycles!
#229817 Frigidaire Affinty won't spin clothes dry!
Posted by Derik on 11 April 2012 - 06:30 PM
Do the doorlock test, start washer and wait for door to lock, then unplug washer if you can open door right after unplugging then the door lock is bad!!!! Common issue on these!!!
#229666 Gas Dryer is only Partialy Heating
Posted by Derik on 09 April 2012 - 07:53 PM
I always replace both and suggest you do the same!!! And also clean vent and blower housing that surrounds blower to keep from having dryer fires and overheating of all components in dryer!!!
