337
Member Since 06 Feb 2012
Offline Last Active Dec 16 2014 11:27 AM
In Topic: Frigidaire PLD2560LCC1 dishwasher runs continuously - keypad doesn't work
25 February 2012 - 10:38 AM
I warrantied the control board and got a new one - that was it, 1st one was DOA. Haven't posted for a couple due to not wanting to jinx the thing but its run 4 cycles without issues so I think that's it. I also cleaned the connectors as you mentioned just in case so maybe that was it but I've a feeling it was the board.
Glad the shop let me get a replacement as they don't accept returns on electronic items - I'll use the place you linked to from now on as their return policy is better.
Thanks for your help samurai.
13 February 2012 - 10:17 PM
Sorry..yeah, the old board had voltage between the P1 and P3 so I replaced it. the new one which worked once and now doesn't work has voltage between P1 and the pin where the yellow wire of the plug of P3 (~8.9v) would go and I get 0.2v on a couple of the ribbon wires (P5, P6) going to the display board.
Seems to be the same as last time, only its completely dead rather than before it would run when the door was closed.
Door switch seems to still be working too. No voltage to the control board if the door is open, power when I close the door.
13 February 2012 - 11:13 AM
Replaced the main control board, dishwasher lit up all nice and ready to go, ran one cycle, got through the full wash cycle at a minimum, not sure if it got to the dry cycle or not but its now completely dead, like before but no washing if the door latch is closed. No buttons work, it doesn't run either. Possibly a bad control board?
- checked the door hook just in case and the switches operate as they should, open when the door is latched, closed when it's open.
- I also checked the line in connections in the box, wire nuts are clean and still good to go, taped up nice and neat.
Got my dad coming in to help on this one too, he was wondering if there could be a relay off the board somewhere that is malfunctioning and blowing the board.
07 February 2012 - 04:31 PM
I had tried to do the service test earlier but none of the buttons on the front panel work. The number display is blank as well.
07 February 2012 - 10:46 AM
found a link to the PDF of the diagram - figured it would work better (plus, I don't have it with me here at work).
http://manuals.frigi...n/154476701.pdf
