337
Member Since 06 Feb 2012
Offline Last Active Dec 16 2014 11:27 AM
Frigidaire PLD2560LCC1 dishwasher runs continuously - keypad doesn't work
06 February 2012 - 06:46 PM
As the title says, I've got a frigidaire dishwasher, about 8 years old, been working without any issues (had clogged drain hose years ago but that was fixed and no problems since). Loaded it up the other day and closed the door and it just started to run, left it to see if it would stop and it ran the entire night. Tried the breaker, no luck, keypad doesn't work or light up. Only way to stop it from running is to leave the door open ajar. Read on an earlier post that the most likely culprit was the control board - pulled it and the R38 resistor was browned and the circuit board around it was a bit discolored.
Just want to make sure that its the control board and not something else that's caused the control board to blow so that I don't put a new one in and it fries again.
Thanks.
