LifeofLaundry
Member Since 12 Feb 2012
Offline Last Active Mar 13 2014 07:42 AM
#224157 2004 Whirlpool Duet Washer model # GHW9100LW1 making knocking noise on spin c...
Posted by LifeofLaundry on 16 February 2012 - 02:16 PM
CUDOS to the Samuri Repair Man!!!!!!!! You got it right on the button! The pulley had play in it and the nut felt tight. It was not. (Always check things twice) Before i put everything back together, i decided to take the nut off and check the shaft and the slot on the pulley for wear. there was none so i tightened everything up tight. You said to tighten the nut and the noise is gone! I SHOULD have been drinking BEER when i was troubleshooting. NEVER do this stuff SOBER!!!Thank-you !!!! Here's what my washer sounds like now.
