woodygg
Member Since 12 Feb 2012
Offline Last Active Sep 14 2013 04:55 PM
In Topic: GE Mongram ZD0710K10SS dishwasher won't start
14 September 2013 - 10:03 AM
There is no lock per se, rather there's a tab with a plastic block on it that sticks out at the top of the body of the DW. That engages a plastic plunger in the hole at the top of the door. That plunger activates 2 microswitches. If the block on the end of the tab isn't pushing it down right or the plunger is sticking those switches don't activate and nothing happens.
turns out that was exactly the problem!  the switch wasn't be depressed all the way anymore.  thanks!!!!
07 September 2013 - 11:52 AM
Is the door switch stuck?
not sure, how would I check?
02 September 2013 - 04:24 PM
check that model number again ..
is there a letter missing ?
ZxD0710K10SS
oops.. yes.  ZBD0710K10SS  thanks
