woodygg
Member Since 12 Feb 2012
Offline Last Active Sep 14 2013 04:55 PM
GE Mongram ZD0710K10SS dishwasher won't start
02 September 2013 - 02:36 PM
Our dishwasher just stopped working. All the lights seem to function properly and are acting normally. There was water left in the bottom of it as well.
I found the paper and have tried running the service mode.
When I activate the service mode, I hear a sound that sounds like the door is locking and the lights all light up for a bit then go off. When I push the various buttons to test each service mode item, the light comes on and I hear a click near the top of the door and then nothing (nothing for any of the button - nothing runs).
In addition, I took out the dishwasher and took apart quite a bit of the drain system, tubing, etc on the bottom and nothing was blocked. I checked the drain tube, the little red valve, etc.
I'm have a vom, and am comfortable with electronics, electrical, etc. so need some advice to hone in on the problem.
Thanks so much!
GE Mongram Range (ZPD30N4) - 1/4 burners usually won't light, if it does it keeps t...
12 February 2012 - 05:46 PM
Hi there,
One of the four burners on our GE Monogram ZPD30N4 range USUALLY won't light. In the rare case it does, the ignighter (if that's what it's called) continues to tick and spark. Please help! Thanks in advance!!!
