fm_weasel
Member Since 17 Feb 2012
Offline Last Active Feb 18 2012 11:40 AM
In Topic: Kenmore 110.86874800 Elec Dryer does not heat or turn off
17 February 2012 - 05:40 PM
Well I extracted the element without testing impedance, but the problem is obvious. There's a break in the element.
Are the timer issues likely to clear up with replacement of just the heating element?
Glad I know what to do now, and can service this myself. Thanks everyone for the help.
17 February 2012 - 05:00 PM
The house breaker for the dryer wasn't tripped, but I flipped and reset it anyway.
The terminal block read 125.7 on the 120V line and 251.8 on the 240V line.
I checked both the terminal ends, as well as the coil itself on the bottom of the heating element for continuity. There was none. I guess this means the element is bad and the solution from here is pretty straight forward?
17 February 2012 - 03:39 PM
There is a schematic on the back of the dryer. Do these images help?
http://dl.dropbox.co...30/IMAG0016.jpg
http://dl.dropbox.co...30/IMAG0017.jpg
http://dl.dropbox.co...30/IMAG0018.jpg
http://dl.dropbox.co...30/IMAG0019.jpg
Duplicated with close ups for readability.
Thanks for your time.
