sh2sh2
Member Since 19 Feb 2012
Offline Last Active Yesterday, 12:14 PM
In Topic: Fafw3511kwo won't spin err e52 or e59 sometimes
Yesterday, 04:30 AM
No the new ones use the allen bolt, u have had a few that I couldn't get apart, the put a lot of loctite on the threads at the factory, but u can split the drums without taking the pully off, but if whatever is stuck is behind the drum it may be tough, I have gotten things thru the opening that the dispensor fills thru in the past without having to split the drums
In Topic: ler4634pq0 Whirlpool dryer new element too hot?
Yesterday, 04:28 AM
You need to use a temp probe or thermometer on the air outlet
In Topic: GE Washer gtup24dem1ww
Yesterday, 04:26 AM
Check for a clog in the airdome
In Topic: Samsung W395 Washer
27 July 2015 - 04:27 PM
Make sure the hose that runs to the switch isn't clogged first!
27 July 2015 - 04:40 AM
My money is on something stuck between the tubs
