sh2sh2
Member Since 19 Feb 2012
Offline Last Active Today, 04:00 PM
#302139 Kenmore 417.40412700 will not start
Posted by sh2sh2 on Today, 03:59 PM
check the door strike for damage as well
#301485 Maytag Bravos Washer MVWX500XW2 bearing issue
Posted by sh2sh2 on 20 August 2014 - 05:16 PM
does whirlpool offer the bearing or are you just doing that to save the customer money?, i just always replace the gear case, corecentric sells rebuilt ones
#301303 Cabrio inner basket removal tool
Posted by sh2sh2 on 18 August 2014 - 05:21 PM
a trick i have yet to try myself, after accessing the tub, pulling the hub, etc. put the unt into diagnostic mode and into spin and pull up in the basket, supposedly it will almost 'unscrew itself'
i do this but instead of spin i put it in agitate works the basket right off the shaft, you can also fill the tub with water to get some upward lift if it is a really stubborn basket.
#300892 Front-loading Frigidaire FWTR445RFS1 won't spin (after basement flood)
Posted by sh2sh2 on 12 August 2014 - 08:27 PM
also motor bearings are probably gonna make noise even if you fix it and get it spinning
#300874 Fun day...
Posted by sh2sh2 on 12 August 2014 - 06:21 PM
"my last one lasted 20 years with out a repair"
#300872 LG Washer WM2350HWC Washability
Posted by sh2sh2 on 12 August 2014 - 06:18 PM
dingy whites are a classic symptom of too much detergent, poor wash cycle choices, also ask if customer is using the "normal cycle" or express wash, the normal cycle on most machines is the most efficient cycle so sometimes gives poor results, and express wash or quick washes are often not long enough to wash clothes properly.
#300693 LG WM2050CW tool P/N 383EER4004A
Posted by sh2sh2 on 10 August 2014 - 09:28 AM
the bent prong tool for the inner clamp is because the inner clamp has a hook, you contract the spring and then unhook the spring letting you take it off
#300587 Maytag Bravos MVWB700VQ0 'UL' code
Posted by sh2sh2 on 08 August 2014 - 03:11 PM
if you push down on the basket/tub assembely does bounce like a basket ball or feel pretty stiff, if it bounces easily then you need the suspension
#300528 Whirlpool LER6611LQ0 elect dryer drum/fan not working
Posted by sh2sh2 on 07 August 2014 - 05:18 PM
2 things to do, pull drum and see if motor runs, if that dosent work check the blower wheel for obstructions that would stop the motor, if nothing found the motor is most likely bad
#300473 Kenmore Dryer 110.66912691 - Does Not Start
Posted by sh2sh2 on 06 August 2014 - 09:45 PM
sounds like a motor, when it does start does the motor making a groaning noise when starting?
#299919 Kenmore Dryer 11086671100 - Heating Element stays on
Posted by sh2sh2 on 29 July 2014 - 08:19 PM
sounds like a heating element shorted to ground, check for continuity from the element terminals to the chassis of the element.
#299832 Coin Op MDG13CSAAL Dryer always running
Posted by sh2sh2 on 28 July 2014 - 08:11 PM
my vote is on a miswired motor
#299831 frigidaire fwx223lbs5 intermittent water leakage
Posted by sh2sh2 on 28 July 2014 - 08:06 PM
make sure tub ring is snapped in place tightly
#299830 Whirlpool Duet Washer W10252714A squeaks
Posted by sh2sh2 on 28 July 2014 - 08:05 PM
can we get a proper model number
#299592 WBB4500E1WW - Broken Hub?
Posted by sh2sh2 on 26 July 2014 - 07:31 AM
yes, you would need to replace the entire basket, the cast aluminum part is not available separately, i believe it is for the plastic tub models.,
