Rasputian
Member Since 22 Feb 2012
Offline Last Active Feb 24 2012 04:55 PM
In Topic: Kenmore 417.44142400 Washer pump buzzing and stuck at rinse cycle...
24 February 2012 - 01:08 AM
Still looking for help here...Any ideas what to try next?
23 February 2012 - 03:09 PM
Correct,it is the water valve that is buzzing. I just did the check to see if it would fill with cold only, and it does, so that is not the problem. And I have taken apart and cleaned the pump. The bellows does stay filled with water, even though the machine does the inital drain to below the internal drum line. Is that normal. Also, is there anyway to adjust the the water level control? I see a plastic screw type adjustment (two actually) but can not find any documentation as to how that adjusts.
