EricEE
Member Since 24 Feb 2012
Offline Last Active Jun 06 2015 12:51 PM
#226472 New Fridge - Looking for ones like Samsung with split fridge/freezer
Posted by EricEE on 08 March 2012 - 07:52 PM
Is your Evaporator Fan good ?
Replaced fan - no dice, display still acting funky. Oh well! Replaced motherboard, put freezer back together, plugged in - compressor starts!
Blowing cold air!
Woo hoo! Now that it works, I guess I'll clean it out really good before putting it back in it's home and setting it to chill down.
Thanks everyone! $200 was definitely cheaper than $2800 - no matter how much I would have loved to justify getting a freezer on the bottom :rocker:
EDIT: Also got my subscription - well worth it! Wondered why I couldn't reply in all the forums :sillytongue:
#226382 Goodman Furnace lesson learned - trust by verify!
Posted by EricEE on 07 March 2012 - 08:47 PM
No matter how careful you are or how good you think you are S happens.
True - it was an install for new construction, so it was probably just overlooked. I'm sure the builder compensated the HVAC whatever the minimal amount was. I do have to hand it to the sheet metal guys - the ductwork on my ground floor/basement is very neat and tidy, and it was installed cleanly - even the joints were taped with foil tape! They used more flex duct that I would care for in the attic, but so far no issues.
It was still annoying it cost me a service call before I got curious and figured out the root cause :thumbsup:
#225856 Goodman Furnace lesson learned - trust by verify!
Posted by EricEE on 02 March 2012 - 01:01 PM
I was reading through the excellent troubleshooting thread and reminded of an issue I was having with my Goodman high efficiency furnace. It was a couple years old and it kept cutting out. I would run for a while, then stop for a while, then run for a while... It was throwing a gas valve code and then it started not running more than it was running so I called for service (under warranty, thankfully). The tech checked the system out and one of the drain tubes for the heat exchanger was full of water. He cleaned out the tubes, put it together and it ran fine. Was near the end of the winter, didn't think much about it.
Next winter, I had the same issue - it worked for quite a while, then started locking out. When checked, water in the tubes. It only happened a couple of times and clearing the tubes solved the problem so I didn't think much more of it.
When it started for the third winter in a row, I started to suspect something might be up :teehee: (OK, so sometimes I'm a slow learner). Luckily the installers left behind all the documentation including the installation instructions. So I started to read them. Lo and behold, there are two drain ports - one for horizontal installations, one for vertical. It most come configured for horizontal from the factory. So I swapped ports and haven't had a single issue since (for two winters now). D'oh!
And yes, I read through and double checked everything else in the install guide just in case! Don't always take the error code at face value and don't always assume the last guy did what he was supposed to do. Probably obvious to the pro's in here, but it's something for us enthusiasts to constantly remind ourselves :pint1:
#225844 New Fridge - Looking for ones like Samsung with split fridge/freezer
Posted by EricEE on 02 March 2012 - 10:53 AM
http://fixitnow.com/...r-fan-problems/
http://fixitnow.com/...e-refrigerator/
Thanks RegUS_PatOff!
#225840 New Fridge - Looking for ones like Samsung with split fridge/freezer
Posted by EricEE on 02 March 2012 - 10:39 AM
Too funny - I did a quick search to find some tips for checking for DC motor shorts and if I included Fridge in my search terms GE came up every time :yucky:
I love this site and refer people to it often!
