horse
Member Since 24 Feb 2012
Offline Last Active Mar 05 2012 08:34 PM
In Topic: Whirlpool Duet GHW9250MT2 Washer won't run top cycles
05 March 2012 - 12:15 PM
Noticed that I could make Normal cycle light up if I turned the dial a touch. Put a little electrical contact cleaner onto dial circuit board and problem resolved. Thank you for your help.
25 February 2012 - 10:03 AM
I messed with the harness connections, pushed on solder connections on dial circuit board and the other cycles started working last night. This morning it was back to only the bottom cycles working. I don't know what I did, maybe the power off while messing with the boards did it. I keep at it and only do one thing at a time and see if I can isolate the problem. Thanks for any help you can give.
24 February 2012 - 09:04 PM
The door is not the problem now, it is not beingable to run the Normal cycle. Is the door latch connection causing this? Thank you.
