revnormh
Member Since 02 Mar 2012
Offline Last Active Oct 26 2012 11:00 AM
DACOR CPS130C Oven won't heat
02 March 2012 - 09:36 AM
Our DACOR CPS130C convection oven is about 15 yrs old and recently indicated F1 on the panel readout (relay circuit failure-?) and would no longer heat, but merely goes through a preheat indication and shuts down. I am an electronic technician and have removed the relay board, tested the main relay (T91P1D22-18F07) which tests good (contacts close upon energizing the coil) and I also tested the high temp limit switch & it is good(continuity). What am I missing? Is it the electronic control unit?
