SJclan
Member Since 10 Mar 2012
Offline Last Active Mar 17 2012 06:27 PM
In Topic: Maytag MDG6000BWW Gas Dryer making funny sound, overheating
17 March 2012 - 09:51 AM
It runs fine and there is no noise when there is no weight in the drum... wet clothes. Once I put more than a few items of clothing the drum just doesn't rotate but no noise.
17 March 2012 - 08:56 AM
Motor shaft turns easily by hand
16 March 2012 - 12:12 PM
I replaced both drum rollers because they were really stiff. Replaced the belt because there was a slight tear in it. Replaced the front felt seal because it was chewed up in one section.
Dryer runs great and quiet with nothing it is. Drum will not move at all once I add the weight of wet clothes. Any ideas??
oops . I meant runs great when there is nothing in it
16 March 2012 - 07:02 AM
The motor and blower are moving freely and together so I don't think that's the problem. The pulley mechanism also looks good and moves freely. The rollers seem a bit stiff and the felt seal on the inside of bulkhead was chewed to bits. Glides look a bit worn.
16 March 2012 - 06:34 AM
OK. I've taken the front panel and bulkhead off. The felt around the top inside of the bulkhead is all chewed up. The glides show some wear. Should they?
How would I recognize if the blower has stripped off from the motor shaft?
