Genno
Member Since 10 Mar 2012
Offline Last Active Mar 12 2012 06:37 AM
Asko W600 washer, rear of drum removal?
10 March 2012 - 11:21 PM
Hi there,
recently came accross your most excellent forum after going one too many rounds of frustration with our Asko W600 washer.
Any forum that combines appliance repair with a love of beer and thing Nihon is alright by me!
Ok so to business. My 12 year old Asko w600 has been making a variety of scraping and screeching noises when it washes. So far have removed front panel, pump and main drain hose. The booty so far amounts to several coins, nails, staples, bits of wire, and lots of hair clips/pins (the last being the main culprit.)
I'm down to one noise which is a scraping/scratching when the drum rotates - removed the rear panel and it appears to be coming from under the round plate on the rear of the drum. There is a triangular plate in the middle of it, with one big bolt. (see picture)
My question is - if I undo this bolt, will it remove the cover plate or is it the key to total drum dissassembly? I'd like to know before I turn it!
Thanks in anticipation,'
Kampai!
Genno
