strumpfman
Member Since 20 Mar 2012
Offline Last Active Today, 02:27 PM
In Topic: Maytag MFI2568AES dispenser door problem/flashing display
15 July 2015 - 01:25 PM
I live outside the USA and not familiar with this fridge. Was wondering if you can disconnect the 12 volts DC power supply from the Mainboard and supply 12 volts DC from a simple 12 V  plug transformer for electronic gadgets. This would enable you to pinpoint the problem and maybe even provide a permanent fix. I used this trick in HVAC systems.
In Topic: Amana ab1924pekw bottom mount
17 May 2015 - 04:06 PM
Huh???? explain!!!Do I need a new board or is there anything else I can do
In Topic: Samsung RF267AERS/XAA drain
24 April 2015 - 08:21 AM
I always carry a 5 feet length of 1/4 water tubing.boil a kettle of water and place it somewhat higher from where yr blockage is.blow in the pipe and then suck a little and quickly remove your mouth.the syphon you just created works miracles for unblocking drain and also nice for iced over evaporator.wear a glove the pipe gets realy hot. If you are afraid try this first with cold water to learn the trick before you start with hot.
In Topic: AMANA Bottom Mount AB1924PEKS
19 April 2015 - 03:41 PM
Thanks for your input,but no quite sure how to perform the diagnostics when I see a fridge which is completely quiet, no display at all(see picture in 1st post). Is this the state of the jazz-board you see often and is their anything worthwhile checking be4 I put a new board in at the risk of it burning out again before leaving my customer. I guess that even repairpartpros.com will not replace a board for free if it looks like the one in my picture. I certainly can not in Israel.
09 March 2015 - 03:18 PM
Thanks guys for your help, Sorry frost and not ice. I replaced both card and defrost thermostat but was there a simple way of knowing which was causing the problem?
