MrSmokesTooMuch
Member Since 25 Mar 2012
Offline Last Active Mar 25 2012 09:40 PM
In Topic: Speed Queen washer (AWM593W2) brake replacement
25 March 2012 - 09:38 PM
Nope, didn't check that. :turned: So that's basically unscrewing the top from underneath and then lifting the entire top up a bit with the lid closed and peeking in to see if the wash basket is spinning during agitation, right? If I don't see the backet spinning then replacing the tub cover gasket is a more likely fix?
