voipman
Member Since 29 Mar 2012
Offline Last Active Feb 28 2015 11:01 AM
In Topic: MAYTAG WASHER (LAT8826AAE) Extra Rinse Cycle
28 February 2013 - 02:23 PM
The Extra Rinse button is a push button.  The button is out and not enabled or off.  The Extra rinse sould not come on.
In Topic: Maytag French door Refrig MFI2568AES not making ice
12 November 2012 - 03:50 PM
I was able to put the icemaker into a harvest mode and ejected ice that's been in there already. At the end of the cycle it filled up with water. The Ice maker has not made ice in weeks. Going into the service mode I was able to get the Ice box fan to go on and off and the damper to open and close. The Ice box thermister is indicating 20 degrees as my thermometer does. It's been my experience that an icemaker needs at least 16 degress or lower to work properly. If this icemaker was in the freezer section it would be much simple er troubleshoot. What is it that is keeping the temperature at 20 degrees?
11 November 2012 - 09:45 AM
Sorry you are right the I missed a number the Mod# is MFI2568AES but there are no numbers at the end.
thanks
In Topic: Bosch (WTMC3521UC) dryer getting E:01 error
02 October 2012 - 10:52 AM
Thanks but it seems the filter was not really cleaned. I had to clean it with a little grease lighting. Works fine now.
Thanks
