OaklandBob
Member Since 30 Mar 2012
Online Last Active Today, 07:34 AM
#315219 Whirlpool Duet GHW91509PW0 - MCU board repair
Posted by OaklandBob on 11 March 2015 - 03:26 PM
From the masthead:  "Workshops in the art and science of appliance repair"
Speaking as a consumer with an interest in things mechanical and electronic and not in the appliance repair business, I
would say that anything that draws aside the curtain of mystery as to the theory and operation of control devices would
be welcome to someone that wants a deeper understanding of how these are designed and function. ( Or fail)
That being said, Those that are in the business of diagnosing and repair are dealing with customers that want their
appliance fixed *now* and are working with information and parts systems that allow them to make service calls
and operate profitably and without worries about legal liability.
I have seen postings here that indicate that some techs would make a repair if it cured a common problem with  a board
that they see on a frequent basis, and save their customer significant money.
Add to that the growing problem of control boards no longer available (NLA) from the manufactures: imagine you are
the owner of an 8 year old $10K refrigerator that has a failed part that is NLA.
So the fun part for us geeks is to figure out what caused the failure in the first place: is it because for reasons of cost
it is being asked to operate too close to it's maximum limits, electrical or thermal, or was it dragged into failure by
something else.
The Samurai has the last word, of course, but as for me, I say bring it on!
#296382 Kitchenaid downdraft fan kird861vss1
Posted by OaklandBob on 14 June 2014 - 08:48 AM
Our KIRD is in our kitchen so I don't have to walk very far to raise my blood pressure.  Our original problem was caused by a power surge on-off-on that killed the unit.  The motor fuse was blown ( overload ) and the snorkel had moved past the upper limit switch into a mechanical stop.  I shut off power to the unit, moved the upper limit switch out of the way, lowered the snorkel a few inches with batteries, replaced the limit switch and the fuse, applied power, pushed the raise/lower button and the snorkel raised to it's proper position and the fan operates. We always keep the unit in it's raised position unless we are cleaning it and as long as the power is on to the system it operates normally.  If power is lost we are back where we started:  when power is restored ( snorkel up) a brief push of the raise/lower causes it to move past the limit switch, a longer push of the button drives it into the stop and blows the fuse. Something happened to the electronic control board that fouls up the sequence of operations and I don't want to buy a new one ( $300) and have it happen again. What I have done is this:  after the last power outage I followed the procedure for lowering the snorkel and getting it back into the proper position and then removed the fuse so the motor wouldn't operate. Now if power is lost or removed the fan won't operate until the raise/lower button is touched and then everything is fine. See my other posts for more details on what I did.
I would be very interested in getting a failed control board to look at and would pay for postage/handling etc.
                                 Hope this helps, Bob
#256292 Jenn-Air and KitchenAid Retractable Down Draft Vent System
Posted by OaklandBob on 29 May 2013 - 04:38 PM
PDuff - We are back in service.  The plug on the wiring harness for the gear motor is an ALEX (Taiwan) 8097 series that uses .045"
square pins.  I made up a couple of test leads with #17 solid wire (.0453") that fit right into the plug. To power the motor I used 2 - 12  volt gel cells in series.  I removed the upper limit switch and lowered the snorkel ( black lead positive lowers, red lead positive raises), replaced the switch, fired up the unit and everything works fine.  Some sort of glitch caused the snorkel to raise past it's
limit but the access plate allows you to see what happened in this case.  I think I'm going to keep the Cook N Vent blower in place
just in case.  Thanks for taking the time to check for more info for me!  Bob
