Raynormensk
Member Since 21 Apr 2012
Offline Last Active Yesterday, 07:33 PM
In Topic: Frigidaire Model no. FRS26R2AW4
28 March 2015 - 09:50 PM
Most likely, at some point, the filter housing froze and cracked, this is very common with this style filter.
Part number: ap3363492
In Topic: Whirlpool Duet Washer - WFW9400VE01
07 June 2014 - 03:05 PM
If the front or back panels are off the machine, it will trip the gfci when you try to run the machine, there are switches under those panels that change the ground circuit, so for testing you will have to tape those switches closed.
In Topic: Frigidaire Gallery Heavy Duty-FWT449GFS1
07 June 2014 - 02:54 PM
There is a tab to the left that you press down on while pulling out the dispenser. You can see it at the top left in the picture.Attached File  00995100.jpg   63.75KB   1 downloads
In Topic: Kenmore 41748102701 won't spin with full load, will with small.
05 June 2014 - 12:04 AM
Thanks, I've got the tech sheet, it would just be nice if we appliance techs could plug in a scanning tool like the auto techs and see rpm, amp loads and such.
04 June 2014 - 10:57 PM
I soooo want OBD II ports on these like on cars to really see what's going on.
