Raynormensk
Member Since 21 Apr 2012
Offline Last Active Sep 06 2014 08:50 AM
#295822 Whirlpool Duet Washer - WFW9400VE01
Posted by Raynormensk on 07 June 2014 - 03:05 PM
If the front or back panels are off the machine, it will trip the gfci when you try to run the machine, there are switches under those panels that change the ground circuit, so for testing you will have to tape those switches closed.
#295821 Frigidaire Gallery Heavy Duty-FWT449GFS1
Posted by Raynormensk on 07 June 2014 - 02:54 PM
There is a tab to the left that you press down on while pulling out the dispenser. You can see it at the top left in the picture.00995100.jpg
#295549 Kenmore 41748102701 won't spin with full load, will with small.
Posted by Raynormensk on 04 June 2014 - 10:57 PM
I soooo want OBD II ports on these like on cars to really see what's going on.
#295538 Kenmore 41748102701 won't spin with full load, will with small.
Posted by Raynormensk on 04 June 2014 - 10:24 PM
No, motor sounds normal, it acts like it's just way to sensitive to any imbalance in a full load so it keeps tumbling trying to find that perfect balance, but never does, if the motor is weak the motor controller could be seeing that as to much imbalance but I can't just have my office order the motor unless I know for sure that is it, cause our parts suppler won't take back opened electronic parts and motors, been burned too many times on that one, wish they would just order that stuff from Repair Clinic but nooo!
Yeah diagnostics come up fine.
#251456 NOT SO CRAZY CUSTOMER
Posted by Raynormensk on 02 April 2013 - 10:09 PM
I would print off a large parts diagram of the area she says had a latch and let her try and find it or let her try and order one from someplace and offer to reimburse and install it once she finds one. The sad thing is, this is not an isolated case. I am seeing these kinds of false memories popping up all the time, I never would have thought appliance repair would involve Psychotherapy, but it seems to more and more.
#231052 Need to replace the tub seal on my kenmore 110.28002010
Posted by Raynormensk on 26 April 2012 - 07:16 PM
Left right right right left right, all lights come on, turn to right till just rinse lit, press start. Let it run through entire calibration.
#230975 GE Profile PFS22SISBSS not cooling .
Posted by Raynormensk on 25 April 2012 - 08:12 PM
The comp is most likely good.
#230902 GE Profile PFS22SISBSS not cooling .
Posted by Raynormensk on 24 April 2012 - 07:32 PM
Yep burned solder joint i have re soldered them in a pinch.
#230897 GE Profile PFS22SISBSS not cooling .
Posted by Raynormensk on 24 April 2012 - 07:00 PM
http://www.repaircli...ber=PFS22SISBSS
#230896 GE Profile PFS22SISBSS not cooling .
Posted by Raynormensk on 24 April 2012 - 06:55 PM
http://www.repaircli...er=PFS22SISBSS
OEM # WR55X10942
#230895 GE Profile PFS22SISBSS not cooling .
Posted by Raynormensk on 24 April 2012 - 06:50 PM
That is the compressor overload clicking so no, the compressor is not running, it is stalling, may not be getting full voltage, may be bad relay on compressor, or a bad compressor. Unplug fridge and let comp cool down then remove relay and overload from comp. and shake it, if you can hear it rattle you have a bad relay.
#230893 Kenmore Elite HE5T Washer model 110.47086600 clothes sopping wet
Posted by Raynormensk on 24 April 2012 - 06:32 PM
Remove all clothes, run spin and drain, remove 3 or 4 t20 torx screws holding on the lower front panel, they are at the very bottom. Now you can get to the coin trap it is mounted to the base with a t20 torx screw or a rubber tab at the front, free the front then you can pull it loose from its rear base mounts and pull it far enough forward to catch some water in a brownie pan. slowly unscrew the coin trap till it drains out, then pull it the rest of the way out and clean it out good in the sink. Put it all back together and see how it does. Screws may be 1/4 inch hex head.
#230814 Spin only engages on FAST setting
Posted by Raynormensk on 23 April 2012 - 10:40 PM
I would replace the timer and not worry about the transmission and you should be back to spinning at high speed. http://www.repaircli...--00837361.jpg]
#230737 "loose" front load washer
Posted by Raynormensk on 22 April 2012 - 09:22 PM
http://www.repaircli...4485917/2220542
#230704 Spin only engages on FAST setting
Posted by Raynormensk on 22 April 2012 - 04:38 PM
This washer has what is called a neutral drain transmission, so after washing the motor reverses from agitate to drain while the transmission is in neutral, then after draining the motor will stop, shifting the transmission into spin, then the motor starts back up again turning in the same direction draining AND spinning. It sounds like that is what yours is doing so i am not sure if anything is really wrong.
