gimlyns
Member Since 29 May 2012
Offline Last Active Jun 15 2012 11:37 AM
lg wm1814cw front load washer had pump replaced, three service calls and still will no...
11 June 2012 - 07:12 PM
my 2005 lg wm1814cw front load washer began to stop after wash cycle, would not spin or drain. I tried all the hints online about unplugging and spinning drum, still not working so called repair service through Sears. They came out and replaced pump motor, said all was fixed and left. The washer still does not complete cycle, wont spin and wont drain. Second repair call zip tied drain hose to pipe and prounced it working again. Third repairman came today, he managed to get it to work through entire cycle. Then put light load in and it worked without soap. He again said he thought it was working correctly. I added soap to load he had put in and it worked through agitation and again stopped. No error msg flashes, machine just cuts off. HELP any ideas?
