c310pilot
Member Since 31 May 2012
Offline Last Active Jun 06 2012 06:11 PM
In Topic: GE Ice Maker ZDIS15CSS surging noises from water reservoir
06 June 2012 - 06:12 PM
I replaced the water valve and it seems to fill now however the water pump is extremely loud during filling. I can here it two rooms away. Is that normal?
31 May 2012 - 04:57 PM
The ice releases cleanly and cutter grid is clean also. All in all this is a very simple system and I would think its the filler valve or control board. It would be nice if these things worked off a water level selonid for as much as they cost. " will disconnect the evap thermistor to default to a 25 min freeze/4 min harvest" I am not sure I follow...............
31 May 2012 - 12:05 PM
I completely disassembled and cleaned the machine this past weekend. I also disassembled the water valve to check for possible clogging. However, I did not run the cleaning solution. There was no scale just white slim on the inlet tube and some lite mildew. I am not sure how the cleaning solution would affect the amount of water going through the valve to the reservoir.
