maynard_james
Member Since 06 Jun 2012
Offline Last Active Jul 18 2015 12:44 PM
Low Voltage @ Evap Fan Motor Model number FRS23R4AQ3
06 June 2012 - 11:36 AM
Hello,
This is my first post here.
I have a Frigidaire Fridge (Mod: FRS23R4AQ3, Ser: LA14314239) & the Evap fan is not running. The voltage was at about 65v. According to the wiring diagram the motor gets voltage from the Adaptive Defrost Control so I assumed the ADC was bad & replaced it. The fan is still not running & now the voltage is down around 25v. I then check for continuity on the wires going from the ADC to the motor & they ohmed out ok. I then thought I might have got a bad ADC, so I tried another & the same thing. No fan movement & 25v. I don't see anything else in the Evap motor circuit that could be pulling down the voltage. I'm at my wits' end with this fridge. Hopefully someone here can help me.
Thanks in advance
maynard_james
