suampman
Member Since 12 Jun 2012
Offline Last Active May 16 2015 12:34 AM
In Topic: Samsung Top Load washer Mod No. WA5471ABP/XAA 01
27 October 2014 - 11:23 AM
More info; Tested voltage going out to the clutch. Voltage jumps to 350vac and drops down to approximately 75-85vac. as the clutch shifts. Supposed to be 120vac. Checked resistance through wiring harness and everything seems good.
Where is the clutch assembly hall sensor?  Could they mean the motor hall sensor? Is this what tells the main circuit board the clutch has shifted? If that is bad it is supposed to get a PE1.  I am getting info from the fast tracks for this washer and another tech sheet found on line.
 I can run through the diagnostics from agitate directly to spin and it works fine. Shifts fine.  Spins up to 1028/+- 5rpm.
Also when it spins up in diagnostics the LED,s do not incrementally go from low to high the way they should.
Tried to get some info from Samsung, but I am not authorized so they will not talk to me or give me the number for tech support.
Any help is appreciated. Thanks.
In Topic: GE wcvh6600 front loader
25 October 2014 - 09:09 PM
Could be your pump not draining the washer. Check the pump.
Does the inner drum move independently of the outer tub. If so the bearings are probably bad and not worth repairing.
Any error codes?
In Topic: Door latch problem on Whirlpool Duet WFW8300SW
25 October 2014 - 08:54 PM
Check the wires and if good replace the door switch.
In Topic: Frigidaire washer won't agitate MD# FLEB8200FS0
24 October 2014 - 08:59 PM
Does the motor spin in the agitate direction? If no motor spin check for power across the timer contacts for agitate.
In Topic: Kitchen aid range, ykerc507ht2, erratic heating, hot light on.
22 October 2014 - 09:52 PM
Should be a tech sheet (usually taped to the back). Use the instructions and the tech sheet to wire it up. If no tech sheet, observe the other switches and wire colors and numbers. Good luck.
