appmed1
Member Since 28 Jun 2012
Offline Last Active Jan 19 2015 11:33 AM
In Topic: GE gas range JGBP24BEW1WH
04 December 2014 - 05:25 PM
When the temperature drops about 30F below the set point, is the ERC sending voltage to the ignitor and gas valve?
I set the temperature for 350F.
Voltage cut out at 204F.
Voltage resumed at 179F.
cut out at 206F.
I checked the sensor from the harness disconnected from the board and it measured 1.22k at 129F.
Amperage between the igniter and the valve was 2.5.
Thanks.
03 December 2014 - 05:14 PM
Did you use new, OEM parts for the replacements?  What are the part numbers?
sensor 8053344 igniter 4342528
Did the range recently change fuels from Natural Gas to Propane or vice versa?
no
Does the flame come on reliably when the control calls for heat?
when I installed the igniter I cycled it about 5 x and it worked flawlessly,
When the temperature drops about 30F below the set point, is the ERC sending voltage to the ignitor and gas valve? When I talked to the customer she said that she would put something in the oven and it would bake fine. The next batch of rolls would be black in half the time.She said she set the temperature at 400F and her thermometer said it was 500F.
Thanks.
In Topic: Maytag dishwasher MDB7749sab0
23 May 2014 - 07:22 PM
Thanks for your input. I replaced the touchpad without resolving the problem. It was the control board.
In Topic: Maytag Dishwasher MDB7749SAB0
20 May 2014 - 10:17 AM
I can't access the link. It says I don't have permission.
Thanks.
In Topic: Duet GHW9150PWo
25 April 2014 - 10:30 AM
What exactly is a siphon problem?
