appmed1
Member Since 28 Jun 2012
Offline Last Active May 30 2015 08:35 AM
Jenn Air range JES9860CAS
15 May 2015 - 08:40 PM
I looked at this range today. The keypad accepts inputs and the control board executes them . After 3 minutes the keypad freezes up and the control board ceases to function. Is this a keypad problem or is it the control board?
Thanks.
Amana AFD2535DEW refrigerator w/ french doors
06 May 2015 - 03:16 PM
I looked at this unit today. The evaporator was iced up, but not solid. I put it in forced defrost and it worked. All the tests checked out. The only problem I encountered is it seems that the damper operation is labored. Any ideas?
Thanks.
Kenmore washer 110.26882503
15 April 2015 - 09:40 PM
I looked at this machine today. The complaint was that one load would come out dry and the next load would have to spin 3 or 4 times. Otherwise the machine is clean and in excellent condition. It spins with very little vibration. I ran 2 loads without incident.
Ideas?
Thanks.
GE gas range JGBP24BEW1WH
03 December 2014 - 10:08 AM
I have a gas range that heats erratically. The temperature fluctuates dramatically. I have changed the sensor and the igniter. Is the ERC next? I have never seen fail in this manner.
Thanks..
Maytag dishwasher MDB7749sab0
20 May 2014 - 12:49 PM
I just looked at this machine. It works intermittently and I can't decide if the control pad is bad or the control board.
The left side of the board is cycles.
1auto-clean- no response
2. normal- auto-clean light comes on
3. light- rinse only light comes on
4.rinse only- quick wash light illuminates
options- none work
start- works occasionally
drain- intermittent
Thanks
