jimvick62
Member Since 03 Jul 2012
Offline Last Active Jul 09 2012 08:11 PM
Whirlpool Duet GHw9100lw2 - repair help
03 July 2012 - 07:19 PM
I have a Whirlpool Duet that I just replaced the tub due to a bearing issue. Now when you start the wash cycle, the tub begins to fill and 3-4 minutes later it stops filling and the error code FH comes up on the display.
I've run diagnostics and it's failing on the c:01 and c:03 codes; all the other six codes pass. I've checked the hot and cold inlet valve for continuity, which it does have, with the valve disconnected. I can't find how to test the flow meter (code c:01).
Any help or advise would be greatly appreciated, thanks in advance.
Jim
