vincef
Member Since 05 Jul 2012
Offline Last Active Jan 02 2014 12:43 PM
In Topic: Kitchen Aid compressor and heat exchanger KSSS48DAX01
18 June 2013 - 12:25 PM
Careful on this one, check for oil where the heat exchanger makes the 90 degree bend into the evaporator.
I have found many to leak at the joint from the heat exchanger into the evaporator.
VF
In Topic: GE GSS20DBMB not staying cold in freezer or Ref side
17 April 2013 - 12:39 PM
Change the relay/overload/start capacitor. On bottom freezer models I will change the board which is clearly burnt
and somehow how the relay assy goes bad also. I've had to do it 3 times in the past two weeks. Weird.
VF
In Topic: GE Refrigerator Evaporator Frosting Up
17 April 2013 - 12:36 PM
Also on GE thermistor replacement, Use a crimp style wire nut and fill the bottom with silicone so moisture cant get into the connection.
I learned this one the hard way... on my own refrigerator.
VF
In Topic: Maytag MSD2959 water lines and more water lines, Help!
31 January 2013 - 01:17 PM
Sorry guys, its a MSD2957AEB. Durham was right, it was a 7 and also right in that
one should not assume when it comes to this stuff. I am experienced enough to know better.
The "Y" is still there. I think that the Y goes to the lower valve (looking in from the back) and the top valve takes
the IM and the dispenser.
In Topic: Jenn Air slide in downdraft JES9800BAS odd problem with Touchpad.
30 December 2012 - 02:43 PM
Looking at the wiring diagram, it doesnt seem like anything would kill power to
the touch pad. I'm going to need a service manual for this range, visually considerably different than the
JES9800AAS, which has a manual posted already. I'm going to put a manual request up
in that forum.
Thanks
Vince
