vincef
Member Since 05 Jul 2012
Offline Last Active Jan 02 2014 12:43 PM
Maytag MSD2959 water lines and more water lines, Help!
17 January 2013 - 05:48 PM
I'm working on an MSD2959*** the unit has 2 water solenoid valves, that parts easy.
Someone tried to repair the lines but put them in the wrong places across the 2 valves.
The outlet line on the top valve is hooked up to the water source at the wall and the inlet to the top
valve goes up top to the filter.
The lower valve hase nothing hooked up to the inlet but leaks at the inlet when energized.
The service manual does not show the routing for the water lines, I downloaded it.
Sad part is I just worked on one 3 weeks ago and cant remember the routing.
Any help would be greatly appreciated.
Thanks
Vince
Need manual for a Jenn Air JES9800BAS
30 December 2012 - 02:47 PM
Touch pad is consierably different than the JES9800AAS, visually. Not sure if
it is the same electronically.
Thanks
VInce
Jenn Air slide in downdraft JES9800BAS odd problem with Touchpad.
29 December 2012 - 06:57 PM
Hi, I went out on a Jenn Air downdraft slide in range today and am a little perplexed.
Got there and touch pad is dead to the touch.. Flipped breaker, waited a few secs
flipped it back on then touch pad would accept functions and touching oven light went on immediately
as powewre went on. started programming control after 1 minute light in oven goes off and touch pad is unresponsive
but clock stays set. Burners work fine so it's all in the control or touch panel. I put a new board in
and have the same problem. Looking at schematic packed in range nothing is inline between pad and control
Instinct says change touchpad but it works fine for 60 seconds. Doen anyone know if there is a syncing
that has to happen like on GE Profile dishwashers? Any help is appreciated. Thanks
VinceF
need wiring diagram or manual for Whirlpool gd25ffcht01
07 November 2012 - 05:23 PM
need wiring diagram or manual for Whirlpool gd25ffcht01.
Thank You.
Wiring for maytag stack sg7800
05 November 2012 - 04:00 PM
Hi, I need a wiring diagram for a Maytag gas SG 7800 stack. Thank You.
