FAQs | Store | Memberships | Repair Videos | Boot Camp | Newsletter | Beer Fund | Contact
AlexM
Member Since 30 Jul 2012
Offline Last Active Jun 04 2014 09:19 AM
#285546 Maytag Refrigerator Model# MFI2067AES; Crazy Electrical Issues
Posted by AlexM on 22 February 2014 - 12:31 AM
thanks so much I will try it tomorrow
#285320 Maytag Refrigerator Model# MFI2067AES; Crazy Electrical Issues
Posted by AlexM on 20 February 2014 - 04:59 PM
You Guys Rock!
I finally got around to donating to the beer fund.  Looooooooong over due!
THANKS FOR SAVING MY BACON, MORE THAN ONCE!      :thanks:   :thumbsup:
#280394 Frigidaire Gas Dryer Model# FASG7073LA0: Replaced coils and still not drying
Posted by AlexM on 07 January 2014 - 09:09 PM
Ikko, Sorry for not getting back sooner, you where spot on. 100% blockage at exterior vent, removed blockage and everything was cool...no, I mean hot!
thanks!
#278644 ASKO Condensor Dryer T721 art# 10772110 - Replacing front bearing wheels and...
Posted by AlexM on 22 December 2013 - 06:35 PM
Mission accomplished.  3.5 Hours from tip to tail.  I replaced the front wheels and belt. I'm hoping next time I can do it in 3.25 Hours.
thanks again for the help.
If someone can tell me how to attach .PDF files I can attach the cheat sheet that someone from ASKO emailed me, it was very helpful...
#266909 Wolf Microwave Drawer Unit: Are The Guts and Trouble Shooting the Same As any...
Posted by AlexM on 03 September 2013 - 12:27 PM
O.K. I finally put in a new magnetron and thermal fuse.  The unit heats water, quickly and everything runs great.
When I removed the old mag, a micro crack became apparent on one of the magnets...found the issue.
Here is my follow up question. I left the sheet metal housing off the back, and noticed that the wave guide channel is heating during operation, is this normal? normal for all microwaves?
#260210 ASKO D3232 Dishwasher, Has Power, No Buttons Work
Posted by AlexM on 07 July 2013 - 12:02 AM
...good news, installed the new board, and good to go.  Thanks again for all the great advice, THANKS!
#256604 GE Trash Compactor Model# ZCG3100: Looking for P/N Nylon Threaded Nut
Posted by AlexM on 01 June 2013 - 07:12 AM
...Update, Replaced the nut with the new metal one and everything is good to go.  Thanks.
#256316 Whirlpool Dishwasher Model# WDT790SAYB, Fills and Drains OK, Doesn't Run
Posted by AlexM on 29 May 2013 - 08:17 PM
Great News!  I installed a new sump assembly, only took about 45 minutes including pulling the unit and reinstalling, works great!  No need for a new board.  Customer is happy and now I know what to do on the next one.
Thanks Agian for the Help!
#255165 Amana Refrigerator Model# SQD26VE, Only 106-vac getting to evap fan
Posted by AlexM on 19 May 2013 - 06:54 AM
This thread all came together on Friday when I put the new limit in and wanted to test it, as the evap fan didn't kick on right away.  Next time I will have a can of key board cleaner.  After about 15 minutes the fan kicked on, good to go.
Thanks to this website, I was saved from replacing fans, heaters, and other parts that wouldn't have fixed it, THANKS FOR THE HELP!
#254821 LG Front Load Washer Model# WM2077CW: LE Error Code.
Posted by AlexM on 15 May 2013 - 08:47 AM
Great News!  I showed up and installed a new sensor and good to go...Thanks!
#254457 Maytag/Whirlpool Bottom Freezer Defrost Issue: JAZZ Board?
Posted by AlexM on 11 May 2013 - 01:06 PM
...from now on, this is the only diagram I need to fix everything! Thanks!
#254297 Maytag/Whirlpool Bottom Freezer Defrost Issue: JAZZ Board?
Posted by AlexM on 09 May 2013 - 09:23 PM
This web site is outstanding, and Kohai, your drawings are awesome.  I successfully got the board replaced, and didn't look at this post in tell just now, but I pretty much pulled everything down and amazing that I didn't break any tabs, its crazy.  this post will help newbees like me stress a little less.  Luckly for me, the customer didn't watch me tugging and pulling.  thanks again!
#253612 Whirlpool Dishwasher Model# WDT790SAYB, Fills and Drains OK, Doesn't Run
Posted by AlexM on 02 May 2013 - 10:18 PM
Outstanding wiring diagram!  Very cool how you outlined the area.  This is very useful and I will check for 120vac at the motor connection.  Thanks A Million!
#251222 Ice Maker in Whirlpool hanging up: ice maker P/N D7824706Q
Posted by AlexM on 30 March 2013 - 10:11 PM
I put a new complete ice maker in and fixed the problem.  Moving forward I will use the complete kit and avoid the call back, THANKS!
#250491 Defrosting Evaporator with Steam or Heat gun?
Posted by AlexM on 19 March 2013 - 10:01 PM
I've always used a blow dryer and steam unit to defrost a fridge.  My steamer failed the other day and I was tempted to grab my heat gun to finish the job.  I figure its a bad idea, but does anybody do it with success?
