AlexM
Member Since 30 Jul 2012
Offline Last Active Jun 12 2015 07:39 AM
Kitchenaid Refrigerator Model# KSSO36QTX00 - Display panel and unit turns off sporadicaly
11 June 2015 - 10:57 PM
This unit is a built in and not mine.  My buddy keeps telling me that it has a mind of its own and keeps turning off and on, but the lights inside still work, even when there appears to be power loss to the control panel?
I know everybody needs more clues, but I thought there maybe something about this model that I could focus my attention on?
Thanks for your help.
Kitchenaid Microwave Model# KEMC308KSS01: Runs, but not heating.
18 November 2014 - 05:13 PM
Howdy,
Its been a long time since I've been on the site.  I searched for the tech manual on this unit, and found two post, but couldn't open any .PDF's.
This is a wall oven/microwave combo, here is my question:  Would it be too barbaric to order a new magnetron, transformer, capacitor, diode, and other parts before I put the entire oven to fix the microwave?
There is no error codes, it just doesn't heat.
Thanks in advance!
Whirlpool Gas Range Model# SF262LXST : Replaced Bake Spark Electrode and Still Doesn...
25 March 2014 - 09:56 AM
The complaint before I replaced the spark electrode on the bake burner was that it would click and spark but no flame, or only stay lit for 30 seconds or less.
I replaced the electrode and it does the same thing.
The broil works great, the burner on top work great, just no bake burner flame...
I have a solid connection between burner and cavity, so I think its grounded, don't know if that matters...?
Thanks
JennAir Gas Glass Cooktop Model# JGD8430ADB: Replacing Glass Top, Problem? No Problem?
10 March 2014 - 02:24 PM
On a gas cooktop like this, do I need to take the whole thing out, like an electric cook top?  or can I replace the glass from the top only?
Thanks in advance.
Frigidaire Front Load Washer Model# GLTF1240AS0 ; Inner basket rubs on door boot gasket...
03 March 2014 - 06:10 PM
The door boot seal seams to be in good shape and no leaking. Just gets squeaker as it spins faster.  I can get it to stop while I pull back on the gasket and move drum by hand.
My question: would replacing the gasket, would I be getting rid of the rubbing?
Thanks
