washertech26
Member Since 12 Sep 2006
Offline Last Active Apr 02 2012 06:21 PM
In Topic: Frigidaire laundry center FEX831CS0 washer tub leans badly
11 February 2012 - 08:18 AM
What condition is the snubber?
In Topic: Maytag Washer LAT98006AAE Inner Drum Spinning during agitate
10 February 2012 - 08:03 PM
Silly question at the bottom in agitate is the transmission turning in agitate,,, If it is I am betting on a brake problem...
In Topic: Maytag performa pye2000ayw have to grab drum help motor to start rotation of...
21 January 2012 - 04:54 PM
There are two different motors you can use but one screws on the blower the other slides on
In Topic: lsr6334lqo whirlpool washer dead
21 January 2012 - 12:42 PM
Make sure to look at the motor overload on the motor (little black box two white wires on it upper right side inside the motor itself) they burn up from time to time..
In Topic: Maytag Neptune MAH4000AWW Front Load washer wont spin
13 January 2012 - 06:26 PM
Leave door open push in the door switch see it the drum move if it doesn't you will need a motor control board I am betting
