washertech26
Member Since 12 Sep 2006
Offline Last Active Apr 02 2012 06:21 PM
#223576 Frigidaire laundry center FEX831CS0 washer tub leans badly
Posted by washertech26 on 11 February 2012 - 08:18 AM
What condition is the snubber?
#223552 Maytag Washer LAT98006AAE Inner Drum Spinning during agitate
Posted by washertech26 on 10 February 2012 - 08:03 PM
Silly question at the bottom in agitate is the transmission turning in agitate,,, If it is I am betting on a brake problem...
#221371 Maytag performa pye2000ayw have to grab drum help motor to start rotation of...
Posted by washertech26 on 21 January 2012 - 04:54 PM
There are two different motors you can use but one screws on the blower the other slides on
#220447 Whirlpool washer Model LSQ7030LQ0 How to replace dogs?
Posted by washertech26 on 12 January 2012 - 07:44 PM
PS dont use so much softener its gross
#220433 Maytag Neptune MAH4000AWW Front Load washer wont spin
Posted by washertech26 on 12 January 2012 - 06:25 PM
Remove the rear access panel see if the belt is off
#220021 Kenmore washer 110.13212200 making noise and sluggish spin
Posted by washertech26 on 09 January 2012 - 05:51 PM
If they drive block is worn you may need a basket drive too.. remove the drive block look at shaft you will see two tits make sure the are rectangles and not one side has what looks like a ramp on it
#219969 White Westinghouse LA400axw2 agitator removal
Posted by washertech26 on 08 January 2012 - 10:23 PM
That is a old Frigidaire washer the newer ones are very similar design but nothing with last as long as your current one these days
#219901 Kenmore Elec. Dryer Model # 110.87562602 Nothing happens when I hit the start...
Posted by washertech26 on 08 January 2012 - 01:16 PM
Thermal fuse is the white fuse on top of the blower housing with two wires going to it .. You can use a meter to check continuity or just put the wires together make sure not touching anything then plug in and try to start it (MAKE SURE IT IS UNPLUGGED FIRST)
http://www.repaircli...se/3392519/2986
#219890 Kenmore Elec. Dryer Model # 110.87562602 Nothing happens when I hit the start...
Posted by washertech26 on 08 January 2012 - 12:02 PM
If it is powering up three things to check first
1. Door switch
2. Thermal fuse
3. broken belt (has a belt switch)
#219837 White Westinghouse LA400axw2 agitator removal
Posted by washertech26 on 07 January 2012 - 05:34 PM
That machine is very old so the agitator wont come off with the help of a maul and replacing the agitator.. Why are you trying to remove it?
#219751 Whirlpool GGW9200LW0 gas dryer not shutting down
Posted by washertech26 on 06 January 2012 - 09:46 PM
Also clean those moisture strips also make sure the machine is level I have had them with the machine wasn't an cloth weren't hitting the sensor
#219730 Maytag MAV8600AWW Washes fine but won't spin-out
Posted by washertech26 on 06 January 2012 - 08:42 PM
When it stops in the spin grab the timer knob and move it back and forth side to side.. If contacts are failing moving it around sometime makes contact and will run then you know the timer is bad
#219725 Maytag Atlantis MAV7600AWW making loud noise during agitate and spin cycle
Posted by washertech26 on 06 January 2012 - 08:31 PM
Look between the pump pulley and the pump you will see metal I am betting.. When you remove the pump Lean the washer against the wall so that water doesnt go everywhere we have hose clamp pliers... Also have a bunch of towels handy....
PS it is so much easier when we can see and hear it to diagnose it thanks for the vid.. PS that is like 130.00 labor to put on so your saving a bunch of money DYI
#219723 Whirlpool dryer won't spin or heat LEQ8621PW0
Posted by washertech26 on 06 January 2012 - 08:26 PM
I have worked on like 25,000 washers and dryer believe me I have done far dumber things then that LMAO :wallbash:
#219720 Maytag Model MAV6000AWN Washer - Spin Cycle Trips Breaker
Posted by washertech26 on 06 January 2012 - 08:12 PM
Could be the motor starting to fail.. I would look under the washer take off the belt and turn the transmission to release the brake and you should be able to make it spin very easy.. Could be belt worn if it is shinny and as it wears belt gets smaller.. Make a vid post it on youtube far easier to diagnose when we see and hear it..
