washertech26
Member Since 12 Sep 2006
Offline Last Active Apr 02 2012 06:21 PM
#219719 whirlpool washer LHA7680N0 leaking tub
Posted by washertech26 on 06 January 2012 - 08:06 PM
Damn I haven't seen that model in years.... That tub hasnt been available for 7 or 8 years now... There is no repairing that machine... Get a new one you sure got your money out of that one
#219718 Kenmore Model 110.69732800 timer not advancing
Posted by washertech26 on 06 January 2012 - 08:00 PM
You are hearing the timer motor it has failed.. Just replace the time its only 4 screws then just take one wire off at a time
#219612 Spin Noise Maytag Performa PAV3200AWW
Posted by washertech26 on 05 January 2012 - 09:28 PM
That transmission is for the pro's only you need a spring tool, brake tools ect... Scrapping noise just for kicks look in the basket holes an see it something isnt poking through one of them....
#219597 Spin Noise Maytag Performa PAV3200AWW
Posted by washertech26 on 05 January 2012 - 08:13 PM
Be very careful with that brake that spring very taught it could come off and seriously injure or maim you... Not worth the risk
#219593 LTF7000ES0 Affinity Washer Heating element replacement
Posted by washertech26 on 05 January 2012 - 08:05 PM
When you turn the screw it pulls on the back plate expanding the rubber to form a seal... Wow I should right user manuals :woot:
#219559 Spin Noise Maytag Performa PAV3200AWW
Posted by washertech26 on 05 January 2012 - 06:02 PM
Make a video post on youtube you have me a little confused... If it spins but doesn't agitate then the transmission is bad or the agitator is stripped at the bottom, but that isn't very likely.
#219273 Whirlpool washer LSR5233EQ2 has a bad smell
Posted by washertech26 on 03 January 2012 - 07:38 PM
Try a cut or two of white vinegar it will disinfect machine if still smells do another load with bleach
#219257 Maytag Washer PAVT444AWW: clothes still wringing wet after spin.
Posted by washertech26 on 03 January 2012 - 05:02 PM
When you put the front back on the that piece of metal at the bottom was hitting the pulley. You just reach under and pull it down a little...
When under the machine I turn the pulley and watch to see if it releases the brake (above the pulley)...
#219056 Whirlpool Duet # GEW9200LWO
Posted by washertech26 on 31 December 2011 - 09:30 PM
The motor is a goner because of the lint.. Its either replace it or the motor.....If you repair it have a 1/2 extension and a ratchet to remove the blower and look at the wheel you will see writing on the edge tells you to remove this way.... Take blower off before you get the motor sometimes you break the blower wheel.. Just a small piece of advice.
Also look on the top of the heater housing especially in the back near the bulkhead pull off the lint and look how it has been cooking on there... That's where the lint fires can start you might want to clean it once a year and it will save you buying another motor....
#219050 Whirlpool Duet # GEW9200LWO
Posted by washertech26 on 31 December 2011 - 08:42 PM
Motor is shot if you look at it I bet it is covered in lint
#218924 Slipping Drive belt on Maytag Model A512
Posted by washertech26 on 30 December 2011 - 05:27 PM
Transmission is seized up so I would junk it... Its an old machine and the parts alone are over 300.00 plus 10.00 for a spanner wrench... It is one of the easier ones to put on but cheaper buying new I think...
#218838 Kenmore Dryer 110.73942101 - no heat
Posted by washertech26 on 29 December 2011 - 08:13 PM
Even heat board is 75.00 are you return the core..
I bet I have replace over a hundred of them failed all the time... Thats why I always replaced all three you replace just one always got a recall
#218748 Maytag Washer PAVT444AWW: clothes still wringing wet after spin.
Posted by washertech26 on 28 December 2011 - 11:08 PM
No problem let me know how it goes
#218739 GE topload Model #WJRE5550H1WW loud roaring during spin cycle
Posted by washertech26 on 28 December 2011 - 09:14 PM
Repairing a GE washer
1. Pull pin
2. Drop grenade into tub closing the lid
3. Run like hell
You can tell I really like GE washers and dryers...
Get another machine before you waste your time and money repairing the POS... I have put dozens of transmissions in those things and it is a pain in the butt... Take the money for the parts get another washer and save yourself doing this :wallbash:
#218737 How to test dryer - dries slowly - GE DPSR513EA2WW
Posted by washertech26 on 28 December 2011 - 09:08 PM
On high machine empty venting disconnected is it hot inside or just warm? That unit has two electric coils for the heater they are thin and fragile and not unusual for one to break.. To test you need to remove the from and the belt and drum (huge pain in the butt) Then I take a pen or screw dryer moving the coils gently and see if it is broken... If broken you just remove the four screws holding the assembly in place just removing the wires.. What out those damn parts are sharp..
http://www.repaircli...er=DPSR513EA2WW
Wow that part has gone up :(
