LazarusLong
Member Since 06 Aug 2012
Offline Last Active Sep 16 2012 08:26 PM
#238588 Fridigaire Front Loader neither agitates nor spins
Posted by LazarusLong on 29 August 2012 - 09:17 PM
Time for an update! Well, I took your advice and sent away for the remanufactured SCU. It arrived in about 3 days, so I went to replace it. Now the washer has a dryer on top of it, and both are in a closet with about 4-6 inches clearance all around, so I did want to pull them out. So I went in thru the bottom front panel often going by touch only - not much space (I am used to that from working on small cars!). Well I finally got the old one out and the new one in (I compare this to laprascopic surgery - you know where they pull your liver out thru a tiny hole in your belly button). Put things back in place and started her up. SUCCESS! It ran four loads.
But HEARTACHE! The motor quit in the middle of a cycle. Hmmm. I got out the old meter and was touching the brush on the motor to see if it had voltage when the motor suddenly started. I then watch the motor and there were a lot of yellow sparks coming from where the brush touches the commutator. Bad - blue sparks are okay, yellow are bad (indicates something melting). Tried to clean the commutator, and it did run for a few more loads, but then died completely. Oh, well. Back to the internet - ordered a motor ($104 with shipping).
4 days later it arrived. Back under the machine. That motor is heavy - especially at the ends of my arm, the brackets are a PITA, and of course no room to work - more use of nut drive by feel. Finally, got the old one out and new one in. But wait! Now I have to get the belt back on. Finally realize, I do not have the leverage in that tiny space to stretch it. Thinking darn, I am going to have to pull the washer - even tho I have spend hours working not to. Then go a bright idea - maybe I can lift the dryer up and get to the pulley from the top.
Got my son and two scissor jacks from our two cars, and some 2 x 4s and 4 x 4s. Was able to jack the driver up 2 feet - steady it with a 4 x 4 crib and stick my body in between. WIth my son holding the belt on the motor spindle and I stretching over the pulley, we got it done! Hurray. [see the photo in attachment] Now jacked it all down (had to go under the house to reconnect the dryer vent), and put things back in place and started her up, yet again. SUCCESS! Have now run many loads and it is humming along (until the next part breaks, no doubt!).
Lesson learned: persistence and good advice! Plus a willingness to lie on the floor in all sorts of wierd positions. BUt you say get a new one. HOWEVER, the cheapest stackables are about $2000 and 6" too big for the closest (is everything in America oversized now????). I don't need 7 cu ft!
Thanks for the site - my donation was well spent. I expect I will be back here within a few years.Attached File  Washer.jpg   65.02KB   11 downloads
