mmpiedra
Member Since 07 Aug 2012
Offline Last Active Aug 09 2012 10:12 PM
In Topic: Maytag Large Capacity Washer/Dryer Combo Unit-Not spinning
09 August 2012 - 10:15 PM
Thank you so very much for your expertise and patience. I went to a local parts store and replaced the switch with a generic micro switch for $6.71. Laundry getting done tonight...I am out of the dog house....for now. :thanks:
09 August 2012 - 04:59 PM
Bingo!!!!!!!!!!!!!!!!!!!!!! :rocker:
I removed the top, located the switch, tested the connection by doing a hard connect (red/black) and the machine began to spin.
It looks a little worn and toasted inside....
Lid Switch (Small) Part #436285
09 August 2012 - 02:54 PM
Okay, let me take a look. Interesting that you said its the lid switch because when I disconnect the power from both machines and then reconnect it, the "IE" ERROR shows on the display, if i open the lid and close, the ERROR clears and the machine begins to fill up. I know its hard to tell, but could any of this been caused because it was overfilled with laundry? Thanks!
09 August 2012 - 01:18 PM
OK, when the Washer should be running,
one Meter Probe on the White wire of the clear Relay
other Probe on one Black wire of the black Relay
then:
other Probe on other Black wire of the black Relay
Nothing registered on the meter
09 August 2012 - 01:13 PM
Yes, you are absolutely right. I did do that and nothing registers on the meter for either black cable.
