FAQs | Store | Memberships | Repair Videos | Boot Camp | Newsletter | Beer Fund | Contact
tmfixit2
Member Since 20 Aug 2012
Offline Last Active May 29 2014 11:17 PM
Kenmore Elite 596.73502200 repair manual
28 May 2014 - 07:45 PM
Hello.
Looking for a repair manual, or at least a schematic, for this Kenmore refrigerator.
Or something close that might help.
thanks in advance.
tm
Kenmore 110.92585800
19 April 2014 - 09:08 PM
Hello.  Trying to find the size of the basket for reference.  Gonna buy a new washer and want to get one a bit bigger.
Next question.  Recommends for front loaders, please.
Kenmore Softener 625.348491 resin replacement
21 December 2013 - 04:50 PM
So the water pressure and volume dropped significantly over the last month or so.  Or maybe it just got so low that it's more noticeable now, but the culprit is definitely the water softener.  Took it all apart and found the bottom filter plugged up nicely.  After cleaning all the gunk out of the tanks I've decided to replace the resin.  Stock from Sears is expensive but I see a lot of replacement type resin.  The repair manual says 'high capacity resin' but I've found only regular and fine mesh resins.  Don't exactly know the difference.  Can I purchase the correct resin here?
tony
Sears 110.92585800
12 December 2012 - 02:08 PM
Hello, again.
Today my washing machine is starting to act up.  It appears that it spins too slow.  If I move it back and forth by hand it feels tight but after a couple of back and forth turns, it frees up a bit, but not for long.  I had reports of a burning type smell, but I did not smell this myself.
My conclusion is that the clutch is shot and binding.  What I'm looking for is a confirmation that this is the likely culprit for this type of problem.
Thanks in advance.
tm
Maytag MTF2656EEW refrigerator - no water to icemaker
28 November 2012 - 11:24 PM
Hello, again.
Problem is with a Maytag MTF2656EEW, there is no water dispensed to the icemaker.  The water valve works out of the unit, but not when connected.  I've looked through the files and not found a repair manual.  If there is one available under this make/model or another similar unit can someone point me to it?  Or any other pointers, for that matter.
thanks in advance,
tm
