Linden
Member Since 26 Aug 2012
Offline Last Active Sep 03 2012 09:28 AM
In Topic: Maytag MAH6700AWW error E3
02 September 2012 - 10:47 AM
Yes the blue link. This appears to be the correct one: http://www.repaircli...mber=MAH6700AWW Out of stock too till mid month.
01 September 2012 - 11:22 PM
To be a little more specific I followed the link offered above to the control board - I suppose I should have been more a little more skeptical and vetted the information first. If I were to return the board and the motor and wait for the correct replacement - I assume it would be shipped when the returned items had been received - I would be looking at minimum of a couple more weeks with a bum washer. The alternative would be to plink down another $300 for the correct board at which point I would be into this affair $900.
01 September 2012 - 09:38 PM
Yes, from Repairclinic and no, it doesn't, and I'm already out expedited shipping on two parts neither of which fixes the problem. Thanks for the prompt reply.
01 September 2012 - 08:44 PM
So, the board arrived - it is for a model with more wash options and a 4 digit digital display. There are no connectors on the machine wiring harness for two of the connectors on the control board. It does fit - same size plastic body. Starts a wash cycle, stalls with "Hr" on the display (can't see two of the LEDs though so I might be missing something). Cancel and restart - drains water (and soap) and then washes normally. Bit of a disappointment. Likely I will return the parts and spring for a new machine.
31 August 2012 - 11:34 AM
Will give this a try...
