Tone Blair
Member Since 19 Sep 2012
Offline Last Active Mar 28 2015 02:07 PM
#313821 Thermador Freezer T24IF70NSP/18 FD 8809 - bosch made Making whistle sound...
Posted by Tone Blair on 20 February 2015 - 11:40 AM
Helps big time!
#312873 FPHD2481KF1 - FRIGIDIARE DISHWASHER - MULITPLE ELECTRICAL PROBLEMS
Posted by Tone Blair on 06 February 2015 - 11:25 PM
Installed new computer today, all checked out good, fingers crossed no call backs.
So what I think was happening was the turbidity sensor wasn't installed correctly at the factory, and the water leak corroded the sensor and connector and eventually shorted main computer.
I didn't catch the sensor leaking before, so it shorted out the new computer I previously installed.
This time I installed new sensor, cleaned up the wire connector as good as possible, even though it were a little worn still.
Everything worked out good, however when running on quick cycle, which on low soil it's only supposed to be 50 min, it jumped up to 99+ min, which the water was pretty clean, so I'm thinking the connector isn't making a great connection, but working still.
I doubt the customer would want to go with a new wire harness, so unless I hear back from the customer, I'm calling it fixed.
#312560 FPHD2481KF1 - FRIGIDIARE DISHWASHER - MULITPLE ELECTRICAL PROBLEMS
Posted by Tone Blair on 02 February 2015 - 06:52 PM
Chat_FL....
Well, what can I say? I gotta be the dumbest person ever!
Door switches good, my plugging them back in, bad!
After all that, I didn't plug the neutral wires back in properly, one of the spades was outside of the connector!
Plugged back in, all is well!
#310548 Old Sears Forced air Heater - Pilot blowing out when Fan comes on -867.76572
Posted by Tone Blair on 03 January 2015 - 02:22 PM
Hey guys long time, but I finally got back out to check it, and the exchanger was absolutley cracked!
Thanks for all the help!
#307961 Dacor range oven temp not correct. Egr30s06sbk
Posted by Tone Blair on 21 November 2014 - 01:11 AM
Yea I am going to test it first to see if I get the same results, at first I was thinking it was the ERC, but it's been crossing my mind that it's the relay board, we'll find out Tues!
#305805 Ge monogram model ZISS48DCASS - Defrost drain pan/tube freezing up
Posted by Tone Blair on 16 October 2014 - 11:25 PM
Yea, hopefully no call backs on it, it was a pain, but definitely went smoother than I expected, and although I would do it again, I don't mind if I don't see one for awhile!
Thanks for all the help and insight!
#305701 Ge monogram model ZISS48DCASS - Defrost drain pan/tube freezing up
Posted by Tone Blair on 15 October 2014 - 09:03 PM
happy to report that the repair is complete and as far as I can tell it's working properly.
I must of got lucky because it ended up going smooth as possible, it took about 3 hours, and good ole Ge even give you a squirt bottle to make sure the pan drains fine. Thanks for telling about the drain tube kinking up so I paid extra attention to that.
Fingers crossed no call backs!
#291684 Samsung top load washer Md. WA5451anw/xaa 02
Posted by Tone Blair on 24 April 2014 - 09:25 PM
I'm pleased to announce that I installed a new wire harness (both upper and lower), and bam! Success!
Machine is working fantastically!
#291350 Samsung top load washer Md. WA5451anw/xaa 02
Posted by Tone Blair on 21 April 2014 - 11:30 AM
DC93-00055C i think this might be it. I ahould have it in a few days.
#291238 Kenmore elite washer 110.45081404 F06 code
Posted by Tone Blair on 19 April 2014 - 07:41 PM
Bam! Installed Mcu, people gonna have clean clothes in the morning!!
Thanks again guys
#290624 Samsung top load washer Md. WA5451anw/xaa 02
Posted by Tone Blair on 11 April 2014 - 03:18 PM
WA5451anw/xaa 02
8e error code. Mems sensor error
Fast track says to check output of mems, not sure how to do that or where to test.
Tested harness, was getting continuity.
Is this a bad sensor? Sub PCb? Or main PCb? Or something completely different?
#286090 amana fridge SXD25S2W - FAN/DEFROST ISSUES
Posted by Tone Blair on 25 February 2014 - 10:26 PM
UPDATE - 2/25/14
Done Dada, installed heater and thermostat, fan running, heater running, fridge working good!
#284671 Maytag coin op washer MAT12PDLAW
Posted by Tone Blair on 15 February 2014 - 09:05 PM
Replaced water valve, bam story over, repair good!!
#282640 FRIGIDAIRE FL WASHER ATF6700FS1 - ERRATIC BEHAVIOR
Posted by Tone Blair on 28 January 2014 - 12:05 AM
bad drain pump, good to go!
#275044 Kenmore washer. 11024964301
Posted by Tone Blair on 22 November 2013 - 12:02 PM
Fairbank - agreed, unfortunately im in the lack of skills category, so if you could offer some practical advice that would be great. I looked at the schematic, might aswell be latin.
So, any suggestion? Other pointing out the obvious?
