niobrara1
Member Since 24 Sep 2012
Offline Last Active Jan 13 2015 09:37 PM
Viking double oven model ded0275ss
24 February 2014 - 05:40 PM
Looking for a service manual.thank you.
York model pbwu-ld12wqbod
09 February 2014 - 03:05 PM
Unit is winning,unit would only run 2 minutes shuts down after flame coming on ,cleaned sensor old control no codes,went to York supply house they said replace control. Ok,replaced unit comes on now will run 8 to 12 minutes shuts down ? Noticed water coming out of bottom . Anyone have a Manuel for this unit,found out I am third guy out on it.And I am not understanding the sequence with the 3 pressure switches or the water. Thanks in advance.
Ge front load wont start
08 June 2013 - 12:24 PM
Model GFWH2400LWW  unit will not light up interface.Power thru ccu to interface. Gray blue yellow and red. 7 volts and 13.To interface. Cant tell what the red should be. Will not go into diagnastic.I'm thinking interface but would like to understand the red wire a little better. I cant read what it should read from the wiring in unit.
