jhruzek
Member Since 29 Sep 2006
Offline Last Active Jul 06 2015 04:39 PM
In Topic: Samsung WF338aab won't drain or spin
01 July 2014 - 02:25 PM
We are about to buy our replacement Samsung washer.  We have a water softener and carbon filter system.  Could this have had a negative effect on the former washer?
30 June 2014 - 09:50 PM
I do clean the filter annually.  The debries was about 2 cups of sand like gritty material, with some of the pieces being oddly shaped slate like pieces, up to the size of a quarter.  We had the shocks replaced back in March.  The repairman suggested that maybe the original problem may have been the spider going out.  He did not pull the drum.  Is there any other procedure that I should have had him do to confirm that it is the spider?
30 June 2014 - 09:46 PM
I had a Samsung authorized repairman out today.  He says the 2 cups of blue/gray debries is coming off of the Spider.  His quote to fix it is over $1,500.  Anyone have a Breakwater Blue washer with steam still in stock?
30 June 2014 - 05:28 PM
Sounds like we will be shopping for a new washer.  Anyone have a Samsung washer with steam in the Breakwater Blue still in stock?
30 June 2014 - 04:48 PM
It does sound like something is running.  I tried to drain the water using the emergency drain line, but it was coming out so slowly, I used a sponge to remove what remained in the drum.  I then opened up the filter.  That is when a bunch of the debries and more water came out.  I suspect at least 2 cups of the blue/gray stuff.
