bayouboy
Member Since 01 Oct 2012
Offline Last Active Jul 29 2015 12:51 PM
#316743 Amana NGD7200 Gas Dryer - Cuts on and Off...Cycles but never gets HOT
Posted by bayouboy on 01 April 2015 - 03:48 PM
The added air will cause the flame to crazy things. Sounds like you got it fixed.
#316636 New front washer with loud banging sound gfwr4805f1rr
Posted by bayouboy on 31 March 2015 - 10:54 AM
was the shipping bolts removed?
#303449 I think A/C Capacitor is bad but want to make sure
Posted by bayouboy on 16 September 2014 - 04:41 PM
Bad cap if it read 0 on the fan. Replace and enjoy the cold air
#300403 Roper dryer RGD4640YQ1 need part # for door catch
Posted by bayouboy on 05 August 2014 - 04:35 PM
Part number: W10610880
#297757 GE GHWN5250D0WS Washer Cycle Problems
Posted by bayouboy on 02 July 2014 - 01:36 PM
Sounds like your cold water inlet screen is clogged.
#297223 Maytag LDG4914AAE gas dryer will not heat
Posted by bayouboy on 25 June 2014 - 03:33 PM
The flame sensor shows NO continuity.
Replace the flame sensor. AP2910747
Part number: ap2910747
#295046 ge refrigerator model gss20ietaww
Posted by bayouboy on 31 May 2014 - 11:45 AM
Pull the fridge out from the wall and see if the noise is by the compressor of from behind the metal panel above the compressor area
#295039 ge refrigerator model gss20ietaww
Posted by bayouboy on 31 May 2014 - 10:46 AM
Sounds like the fan blade is hitting ice due to a defrost issue. Is there frost or ice on the back wall of the freezer?
#295031 GE Monogram Fridge ZISS420DXSS works too good!
Posted by bayouboy on 31 May 2014 - 08:49 AM
If the damper is sealed up with silicone that's where I would start. if the damper door is broken it will allow to much cold air in the FF section. I know you said all the thermistors were in specs but they are cheep enough to replace all of them.
#295029 GE Monogram Fridge ZISS420DXSS works too good!
Posted by bayouboy on 31 May 2014 - 08:31 AM
Did the fridge have any problems when you bought it? Did you lay it down when you moved it? Put a thermometer in each side of the box and check your temps that way. Is the condenser coil clean?
#294723 GE Monogram Fridge ZISS420DXSS works too good!
Posted by bayouboy on 28 May 2014 - 08:31 AM
Sounds like the damper may be broken in the refrigerator, back left corner. Part 367 on the breakdown.
#293221 Need a water valve part # for samsung fridge RFG293HARS/XAA
Posted by bayouboy on 09 May 2014 - 04:58 PM
Part number: DA62-02623A
#292192 Kenmore Upright freezer model #1069205581
Posted by bayouboy on 29 April 2014 - 12:54 PM
The brackets were removable on both fan motors, I swapped them over and everything fit. I would hate for the customer to have to replace his old freezer because of a NLA fan motor. Thanks PDuff the Part number: 482731
Part number: 482731
motor worked.
#291606 Amana Washer Lid Lock
Posted by bayouboy on 24 April 2014 - 08:19 AM
its sounds like a bad door latch. part number Part number: W10404050
#290974 Kitchen aid washing machine KAWS750JQ4 stops during wash cycle
Posted by bayouboy on 16 April 2014 - 04:47 PM
sounds like a bad lid switch. Part number 3949247
