krr1101
Member Since 09 Oct 2012
Offline Last Active Feb 26 2015 10:58 PM
In Topic: Maytag Bravo Electric Dryer MEDB400VQ0
20 November 2014 - 10:59 PM
No it is not, but that was with the old board. With the new board I first got F08 then F09 then F01.
I will hook up the motor and test it tomorrow. Thank you so much!
In Topic: Sears Kenmore washer 110.28422700
18 August 2014 - 10:08 PM
It worked like a champ. Used Putty knife to depress clip like you said and wala ! Control panel came right off.  Replaced the lid switch and all is well now!!!
Thanks for all your help.
17 August 2014 - 10:56 PM
Wow great thank you so much. I will see tomorrow if I can get it off . I will let you know how it went later.
16 August 2014 - 10:22 PM
While searching the web I found someone else having problems removing the control panel on this washer. Is there any one out there that is familiar with this model washer?
Kenmore washer. model 110.28422700 type 111-07 I have the timer I just can not get in the control panel from the back or sides. I need to know how to get the top control panel open to install the timer.
16 August 2014 - 10:14 PM
