hyprdrvr
Member Since 19 Oct 2012
Offline Last Active Oct 28 2012 11:02 PM
Coleman DGAT070BDD Flashes once
19 October 2012 - 04:10 PM
I have a 1996 Coleman DGAT070BDD which falls under the recall notice and has not be inspected yet. However, after a recent rain storm, the heat stopped working. I noticed a water leak had made it to the control board, and it had some corrosion on it. I replaced the control board but am receiving one flash stating that it had an ignition failure. I watch through the site glass to see that the ignitor and flame came on and went off 3 times before the trouble code flashed. I tried cleaning the flame sensor and checked continuity between the sensor tip and the solder joint on the control board which checked good. I even replaced the sensor. Is it possible the new board has a problem or is there something else I need to check.
